what year model tpi has the biggest throttle body
Subscribe
Dec 31, 2000 | 01:34 AM
i just wanted to know which year tpi engin has the biggest throttle body and if it would fit on a 85 305 tpi camaro stock engin cause i am planning on going to the salvage yard and picking up that one
Reply 0
Dec 31, 2000 | 02:17 AM
I think every year, every model, the TB is only 48mm.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Reply 0
Dec 31, 2000 | 04:36 PM
They're all 48mm. Since you have an 85 make sure you get one off a 85-88 (or maybe 87) tpi so that your stock throttle cable setup will still work. You can also have it bored out to 52mm for $150 or so.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Reply 0
Jan 1, 2001 | 12:51 AM
They're all 48mm, and you need one from an 85-88 setup, like was said above.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Subscribe
