Diagnose this
Old Jan 3, 2001 | 11:21 AM
jRaskell's Avatar
Diagnose this
I'm gettting a code 44, which according to my Haynes manual indicates a lean condition. However, my exhaust smells rich. Could this be a bad O2 sensor? What are the other possibilities. It idles a little rough once it's warmed up, bouncing between 600 and 750 rpms. The car still runs good otherwise. I'm hesitant to run it if I am indeed getting a lean condition. I don't want to do any serious damage.
Old Jan 3, 2001 | 05:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Pull the sensor out and if it is black and sooty, than the sensor has failed and fooled the computer into thinking that it is running lean so the computer overcompensated for a condition that didn't exist.
Even if it isn't black and sooty, a new sensor is always a good starting point when you are dealing with oxygen sensors. Good luck.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
GTAman
Mar 15, 2019 11:40 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Magman
Sep 12, 2015 11:55 PM
Thaney9
Aug 29, 2015 03:16 PM
Bryan F
Aug 27, 2015 07:28 AM
