1.6 rockers and Alum heads?
Old Jul 28, 2007 | 04:47 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Need advise.
How much extra lift will a 1.6 rocker give over a 1.5? My cam specs are 208/221 474/501 @112
Also I have a line on a set of used ZZ4 alum heads. Are these better than Vortec heads? The ZZ4 heads are $550 for the pair?
What do you think.........THANKS
Old Jul 28, 2007 | 07:25 AM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
Re: 1.6 rockers and Alum heads?
Your .474 lift becomes .5056 lift, your .501 lift would be .5344 lift. However, that sounds like a ZZ3/ZZ4 cam and it was .474/.510 lift, so .510 lift would be .544 with a 1.6 rocker.
The ZZ4 heads are not better than the Vortec heads. They are lighter, but they don't flow as well. I've got a set of the ZZ3/ZZ4 heads on my engine right now and at 10.6:1 with a Holley stealth ram, SLP 1 3/4" headers and a 220/230 .510/.510 cam, I made 299 RWHP and 338 ft lbs. I'm going to put better heads on it soon and go in search of 400 hp (as well as long tubes and a bit more cam).
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
Brendankup
Aug 30, 2015 01:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
