Does Hot Cam require ECM Changes
Old Jul 28, 2007 | 09:19 PM
69firemaro's Avatar
I got my engine started. It has a Comp Cam (very radical) I have to open the throttle on the TPI throttle body for it to start, but when I do it will run. My question is do I need to make ecm changes, or are there any other changes I should make to better tune my engine for it's mods? It is a 350 bored .060
12 to1 compression pistons. I am running an 86 TPI unit with MAF. It seems that the engine is needing to idle much faster than stock idle speed. Thanks for help guys
Old Jul 28, 2007 | 11:39 PM
Abubaca's Avatar
Re: Does Hot Cam require ECM Changes
Yes. You'll need a custom tune.
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Start reading on the prom board and get ready to dig in.
U should have learned to tune on the stock setup first before doing mods, it would have made your life alot easier.
Old Jul 29, 2007 | 07:10 AM
69firemaro's Avatar
I know you are right 3.8TransAm, but my engine wasn't stock from the begginning. It was a carburated engine and I wanted to go TPI
junkcltr
Aug 2, 2019 11:12 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86IROC112
Aug 21, 2015 07:20 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
