New Ram-Air Idea for TPI Camaros
Old Jan 7, 2001 | 07:55 PM
CamaroX84's Avatar
Everybody knows how to make a ram-air for a TPI Camaro (Run tubing from the front grills to the air box which has been cut out, with two K&N air filters in place). Well, how bout this idea:
1. Gut the air box where the filters normally go.
2. Run some flex-pipe from the two front grills up to the air box.
3. Do not put air filters in.
4. Put a K&N Cone Air Filter on the end of the throttle body.
I know it says that the K&N Cone Air Filter only works on Speed Density cars. But this is assuming that you are completely removing your air box. So, if you keep the air box there with the MAF sensor, it shouldn't be a problem, right? Well, what do you guys think of this idea? I think it would flow much better than having two K&N's in the air box. Will it work? Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Jan 7, 2001 | 08:21 PM
cobrakiller1989's Avatar
i suggested something similar to this a while back and the response i got was that the MAF sensor has to be after the filter or it will not function right.
My dream were shattered.
good luck
Old Jan 8, 2001 | 12:12 AM
Steve R's Avatar
would it be possible to cut up a MAF sensor and put the element just before the throttle body on one of those cool open air cleaner thingies? so that way it would look like a SD setup but it would still retain the MAF wire just behind the air filter...
-80 Camaro 350, Carter AFB, headers, dual exh, ram air, all sorts of crap
-88 Iroc-Z 350tpi, 3.27 gears, 4 wheel disc, MSD 6a, tpi airfoil, k+n's, white gauges, accel coil, flowmaster, pretty quick
Old Jan 9, 2001 | 03:29 PM
Fastcamaro87's Avatar
yeah if u put the maf on before the filter u will certainly be buying a new one soon, and if the screens are removed, sooner than u think.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
