PCV Fitting on 1988 Camaro intake Manifold?
Old Aug 1, 2007 | 11:14 AM
mlozano's Avatar
Hello
I´m swaping a 1988 camaro TPI on my Jeep. I live in Santiago, CHILE, and bought all from ebay.
My problem is that i have a missing Fitting, the one that goes on the drivers side of the intake manifild and hook the PVC valve hose. Here is a picture of where it goes.
Anybody have a part number or know where can i buy it online?
Here in chile is impossible to find spares for this kind of engine.
Mariano Lozano
Santiago, CHILE
Attached Thumbnails PCV Fitting on 1988 Camaro intake Manifold?-imagen-1.jpg
Old Aug 1, 2007 | 12:46 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: PCV Fitting on 1988 Camaro intake Manifold?
Any parts house or mail order should net u what u need. Most have selections in stock.
Just needs to have an adapter for 3/8 hose coming off of it
later
Jeremy
Old Aug 1, 2007 | 04:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Isn`t that for the 9th injector no ? PCV comes off the valve cover there and goes to the front of the T.B I thought .
Old Aug 1, 2007 | 07:03 PM
mlozano's Avatar
later
Jeremy
Do you know the thread size? or a part number to find it?
Mariano
Old Aug 1, 2007 | 07:11 PM
mlozano's Avatar
Nope... the 9th injector goes below it. Here is a picture with the 9th injector installed.
Mariano
Old Apr 6, 2010 | 11:00 PM
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Mariano
I have the same issue. I need to get a fitting an I don't know what the thread size is on the intake side. Did you ever find out?
Old Apr 7, 2010 | 12:52 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Go to the local plumbing supply or a hardware store you should be able to get a proper size pipe nipple to screw in the hole, I think it is 1/4" npt pipe thread, or maybe 3/8"
Old Apr 9, 2010 | 08:46 PM
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Thanks. I needed the size because when the ceramic coating was applied, it adhered to the inners threads on the intake side and I lost the fitting. So before I use a tap to clean out the threads I'd love to know what size they are. If anyone knows... anyone! I'll try my 3/8 NPT tap and see if it looks close.
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Vintageracer
Aug 11, 2015 08:13 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mustangman65_79
Aug 8, 2015 12:07 PM
