More LT4 Hot Cam Questions
I've been interested in the LT4 Hot Cam for quite some time now, but I am running low on cash and wondering if this will work. I have a stock 89 350 TPI motor, but plan on putting in a few various mods including headers and a 3" exhaust system. Can I use the LT4 Hot Cam with the stock heads (with the exception of the rockers, springs, retainers, and springs? If not, will the cam be ok with stock ported heads? Also, would it be ok to use the stock manifold base? Or could I/should I get that ported as well? Any help would be much appreciated. Thanks.
[This message has been edited by CamaroX84 (edited January 07, 2001).]
I'm running a Comp 218/224, .495/.503 lift w/1.5's. It's very similar to the Hot cam. I'm running stock ported heads w/3 angle vj, ported plenum, ported stock intake and SLP runners. My car runs good with that setup, much better than stock. Lots of torque. Still runs out of air, but I just bought a Super Ram and plan to upgrade heads and intake soon. I made a cold air induction out of PVC and that made a big difference too, FYI.
87 GTA, auto w/2075 stall, 3.27 rear, L98 .020 over,Comp 269HR cam & 1.5 roller tips, ported heads w/3 angle vj & brnz guides, 52mm TB & airfoil, SLP runners, ported plenum, ported intake, Edelbrock TES, AFPR, MSD 6A/Blaster coil, MAF screens, cold-air induction, vortec muffler, heated O2, Ed Wright Fastchip.
hey shawn87gta hows your gas mileage with that setup?? I've heard that a cam with that much duration drives tpi nuts..
-80 Camaro 350, Carter AFB, headers, dual exh, ram air, all sorts of crap
-88 Iroc-Z 350tpi, 3.27 gears, 4 wheel disc, MSD 6a, tpi airfoil, k+n's, white gauges, accel coil, flowmaster, pretty quick
How nasty is the idle on the LT4 cam? I want to be able to have friends in the car -girls in particular :-)and for them to enjoy the ride and not shake at a stop sign. What about gas mileage, too? Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
5.0 Carbed LG4
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Get everything ported that you can while you have the intake apart, its definitely worth it. The LT4 HOT cam has a noticeable idle, and it will thump, but its not so bad as to be undriveable. Tom Keliher has one in his car and has a mpeg movie of his car at idle on his website.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I am going to be using the stock springs with my LT4 Hot Cam. It sounds like an ideal cam for your car, it probably will have a noticeable idle, but like it was said, not too bad.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, LT4 HOT Cam, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
1988iroc350tpi
Aug 14, 2015 07:52 PM
