Problem!
Old Aug 2, 2007 | 10:47 PM
driver8's Avatar
Car: 87 Iroc
Engine: 383
Axle/Gears: 3:73
Problem!
I have restored a 1987 Iroc from bottom to top I finished a year ago and still not driving it yet. The engine was a GM performace 350 with vortec head so I purchased a intake from scoggins and fired it up it over heated and ran like crap. I was told the cam was not the right size so I replaced it with one the gm performance put in there ram air set up. Well the overheat problem is gone but the car misses still and the 6 cylinder is not getting getting hot I have replaced the injector I have checked the power to it the spark is good in wire and plug. The timing is set 10 degrees and as i said before it is restored all sensors and other part are new except distributor. Any help out there! I would buy a new distributor if some one made a hei esc do you know of any besides the general.
Old Aug 6, 2007 | 09:42 PM
billydonn's Avatar
Car: 66 c-10 stepside
Transmission: TKO 600
Re: Problem!
performancedistributor.com will make you a new dizzy
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
