tpi iroc fails to start !
Old Jan 12, 2001 | 12:25 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
O.K. G.M. TECH is also helping on this one,but I thought I would throw this out there again to get some more ideas. First off, the car runs great. Starts every time in the morning. Shut the car off...then try to restart, the motor just cranks. After about 10 minutes the @#$ thing starts. This is what we do know: during no fire cond. spark at plugs=yes,fuel pressure at rail=yes,signal to injectors=yes. The car will only fire during the "no fire" stage if starter fluid is sprayed into the throttle blades. The module in dist. has been replaced along with cap and rotor. Well, there it is, my headache for oh about 3 years now.
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old Jan 12, 2001 | 04:36 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Sounds like an injector problem. You said the noid light test is good meaning the electrical is working. Fuel pressure in rail is good and it WILL start when starting fluid is used. That alone indicates a lack of fuel but why it continues to run is beyond me. Let me dream the answer tonight.......
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jan 12, 2001 | 04:59 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
There might be too much cranking fuel being supplied and fouling the plugs. Is this a custom PROM? Did you try holding the pedal to the floor while cranking? The ecm sees wide open throttle during cranking as a clear flood condition.
Old Jan 12, 2001 | 05:55 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Originally posted by irocdaddy: The car will only fire during the "no fire" stage if starter fluid is sprayed into the throttle blades.
Question: How do you start a flooded engine w/ starting fluid?
I know you said you have fuel pressure, but what EXACTLY is the fuel pressure when it won't start? (please post your reply in the ELEC board - to hard to watch the same post on different boards)
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
drathaar907
Aug 6, 2015 04:20 PM
