power Gain from headers
Old Jan 9, 2001 | 11:03 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I have Hooker comp headers I want to install But I have to remove the smog pump first. How hard is the installation ?? Time , hints,tricks??
and how much power should I gain. my current mods are below. but the headers are not installed. How much track time gain is possible?
91 Z28 5.7l Camaro
T-56, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jan 9, 2001 | 11:42 PM
IrocManiac's Avatar
Hey Chris its me Trey I would think you should get around 20hp or so. The hotter the engine the bigger the gain so on yours i would expect about 20 hp.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Jan 10, 2001 | 06:20 PM
Car: 1991 Z28
Hey Trey you know how to rig a horn?? I need it for inspection (3 months over) and I want the inspection before I take off the air pump.
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Old Jan 11, 2001 | 01:05 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
If you take the smog pump off, you may not pass DEQ. If your headers will only work with the smog pump out of their way, then you could have some problems.
I believe the O2 sensor is in the exhaust manifold. Where your headers go. So if you pass Emissions before installing the headers.... in 2 years when you have no 02 sensor, and no smog pump, you'll have to reinstall all that to pass again.
Or am I wrong? I'm not 100% sure, but that's what I've gathered since I've been going through DEQ. At least here in Washington.
I'm also thinking of headers. Dont' know what's best, for performance and deq. Let us both know!
'85 Z28 305 TPI. Edlebrock Strut Tower Brace. IROC wheels. Fog Lights. Upcoming mods: Headers to tail pipe performance. Rear shocks. Panhard Rod. Sway Bars. MSD. New Intake.
Old Jan 13, 2001 | 12:55 AM
Car: 1991 Z28
There is a bung for me to drill out the o2 sensor fittings.
91 Z28 5.7l Camaro
more to come....
My 91 Z28
hectre13
Sep 8, 2015 03:38 PM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
