oil pressure switch location
Old Aug 5, 2007 | 07:01 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
88 formula 350 TPI pic of location of switch would be great or detailed info of where to look
Old Aug 5, 2007 | 07:26 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: oil pressure switch location
There is a switch and a sending unit. I can't remember which is which but regardless, there is one directly behind the intake that mounts off the back of the block, its a big round thing with a single wire going into it. The other is located in the side of the block just above where the oil filter screws in.
You can see both in this pic.
http://mattodoom.com/ta/40600101.JPG
Old Aug 5, 2007 | 07:28 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Try behind the intake manifold, screwed into the block, against the firewall, closer to the driver's side cylinder head?
Old Aug 5, 2007 | 07:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i think what your looking for is oil press/ fuel switch . its above the oil filter on the drivers side . be careful with the plastic plug to it .they get brittle with age . clean it good before trying to take it off , and have a good light to see it . did i say clean the area where it screws into block ? when you put the new one back in don't forget teflon tape on the male threads . worked for me .
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
