Fuel pump test connector location??? 85 TA
Old Aug 6, 2007 | 09:57 PM
wrapper8758's Avatar
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
After months of dragging my feet over intermittent code 44,and fuel pressure dropping/not holding, I need to fix this ..........(o2 sensor new)
I need to find out where my the fuel pump test connector is located.(to jump out and pinch return line)
The pressure drops immediately after initial prime.
Should it be done from the relay, or the ALDL plug.....and which pins should I jumper? I cant find the location ANYWHERE in my service manual,but it is referred to repeatedly in Fuel system diagnosis section.
Thanks guys!!
Old Aug 7, 2007 | 12:06 AM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
Re: Fuel pump test connector location??? 85 TA
The Fuel Pump Test Jumper is located on the wire harness around the blower box / a/c accumulator area in the passengers side of the engine compartment. Its the only thing on the harness not plugged into something. Its pretty small and really easy to overlook. But, its there. If you need a pic I can get it for you.
-Greg
Old Aug 7, 2007 | 05:17 AM
Thanks Greg,
If you have a pic I'll compare locations.
Old Aug 8, 2007 | 10:28 AM
Do you have a pic? not sure if its in the same location as my 85.....
now I made matters worse.......check my other post.
Thanks, Paul
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
