Which TPI system will fit...
Old Jan 18, 2001 | 08:56 PM
CamaroRS's Avatar
I was wondering what year TPI system will work on two piece rear main seal blocks (the ones made before '86)? Also, can you mix and match ecm's, wiring harnesses and the rest of the TPI parts from all years the TPI system was produced? For example, can a 88 wiring harness, a 86 ecm and a 89 plenum and throttle body work together? Thanks.
Old Jan 18, 2001 | 09:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its not the engine that matters, its the heads. 86 and older heads have a different bolt patter than the 87 and newer heads.
Match up TPI components between these years: 85-88 and 89-92. As long as everything is from the same style, it'll bolt together. For the wiring harness and computer, its trickier. I am not sure on the wireharness, but I know 85 is one ECM, 86-89 is another, and 90-92 is the third.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 18, 2001 | 11:17 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Get an 89 ecm to match your 89 plenum, it is the best MAF ecm. You can alter the harness of the 88 to work with the 89; scope out the PROM board older posts. This question has cropped up a few times.
Kevin, is bang on regarding the heads. With aftermarket bases, they generally are designed to work with both.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
