Heads
Old Jan 19, 2001 | 10:24 PM
CamaroRS's Avatar
Heads
I was wondering what the best heads would be for a two piece rear main seal 305 that will be using TPI. Also, what would be the best camshaft to use with heads as well. Thanks.
Old Jan 20, 2001 | 08:17 AM
CamaroRS's Avatar
Any ideas?
Old Jan 20, 2001 | 03:04 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I'm going to send you a lot of head flow numbers from different heads that I've amassed over time.
Take look at the numbers and concentrate on those with the best low and mid lift flow. Don't swayed by max lift flow at the expense of low and mid lift flow.
As far as camshafts, I'd look at CompCams Xtreme Energy hydraulic in the 210 @ .050 range with mid .400 valve lift. Because you have a 305 instead of the larger 350, you might want to even consider one with 6 degrees less duration @ .050 with something around 204 degrees intake duration @ .050.
A lot depends on how you plan to use the engine and what additional modifications you'll make. In picking a camshaft, you need to consider the whole engine package; everything from the air filter to the tail pipe. including rear end gear ratio and transmission. Emissions, idle quality, gas mileage, etc., are also considerations.
Give CompCams a call on their toll free Tech line and they'll recommend one for you.
Hope this helps.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited January 20, 2001).]
Old Jan 20, 2001 | 06:42 PM
98_1LE's Avatar
Jake, would you please send me those flow #'s also? 1le@1le.net
Thx
87 Formula 350 14.61@94.07 before 2OTL, TCI stall, Nitto's, tubular LCA's & panhard
98 Z28 1LE 13.15@107.59
1LE Owners Association
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
