can i put Vortec heads on my 305?
Old Jan 21, 2001 | 10:38 AM
Artic White Z's Avatar
i got a 91 z with a 305. can i get the TPI intake milled so it bolts up to vortec heads? if so would the heads be to much for my engine? i know the heads work great for 350's which im going to build in a few years but i need heads now for my 305. i thought i could just use them until i get my new engine.
Old Jan 21, 2001 | 03:19 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Vortec heads would dump your CR into the toilet. Try 305 SR torkers from world.
Old Jan 21, 2001 | 09:04 PM
JJ's Avatar
JJ
you can mill the heads to increase your compression, I milled a set .030" for a 305 and put them on a 350 later. If you mill your heads that much, you would probably want to mill your "vortec bolt pattern tpi intake" as well so it will "fit" right. But then you pretty much have a matched set.
some people have mated the vortec heads to the stock pattern intake - I don't think I would do that myself however, but to each their own.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
