BACKFIREING...please help.
Old Jan 21, 2001 | 04:03 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Give me a motor and Ill blueprint balance assemble etc.. But when it comes to the electrical forget it......
Heres the problem.. car has been sitting for awhile since i moved up north. I just replaced the modual with a POS wells one just to drive it till I can get a mds on the way from summit.
Anyways I know the timing/TPI/IAC etc. is right. on all wires are on the right plugs etc. but its poping through the exh bad.
Someone told me maybe the distrib is bad and to replace it with a vacume adv. one. would be better. But I know with TPI this shouldnt be done. Id rather just go with a MSD distrib for my car since I have msd everything else. valves are set right etc.
I hate to pay 300 for a dist. and that not be it.
I had JIM FORMATO do my chip and it was on a chassi dyno at ramsies perf.
Not knowing anybody in my new area sucks. So any advice would be great. Any motor info you need can be found on my site in sig.
EDIT BTW no codes have been triped.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf. www.go.to/TPI383
[This message has been edited by TPl383 (edited January 21, 2001).]
Old Jan 21, 2001 | 08:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I had a similar problem and went through a module a week. The pickup had an intermitant open. Popping banging and missing until it wouldn't start at all. Change the module and it would run like a champ for maybe a week, then it would start all over again. This drove me nuts because the pickup tested fine. I took it out and wiggled the small wires and there it wuz! I got a MSD late model small cap distrib and never had a prob again...
Old Jan 21, 2001 | 09:19 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thats along the line im thinking. I figure maybe i pinched a wire putting the cap back on.
Cuz it went from a BEAST or a car to slugish at 1st then when i get on it its a raped ape again at high rpms. Ill just get a new MSD DIST. and coil..
THANKS.
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
