Fuel Injectors
Old Jan 17, 2001 | 12:50 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Fuel Injectors
What size fuel injectors do 86 305 TPI IROC-Z's have? I'd like to get some new one's and dunno a thing about them.
86' IROC-Z
5.0L TPI
Stock(for now)
Old Jan 17, 2001 | 12:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
19lbs. If your going to get new ones get the new Ford SVO 19's for about 240
Old Jan 17, 2001 | 01:33 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Could you give me a little info about those injectors you talk about. What makes them better than other injectors?
[This message has been edited by eatmydust (edited January 17, 2001).]
Old Jan 17, 2001 | 01:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
about 250 cheaper. There in the back of the summit catalog on pg 246 for $197.95 and many people use them on this board
Old Jan 17, 2001 | 01:51 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Anything else? Can I put bigger injectors in? If I can, what would it do?
Old Jan 17, 2001 | 04:48 PM
ScreaminDeamin85Z's Avatar
i have the SVO 19lbs that i have in my wrecked car, maybe you want them. they are in perfect condition with less than 5000 miles(some moron hit me) and i need bigger ones for the 350.let me know if you are interested.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
(dont worry i am switching to the 89 ECM)
Old Jan 18, 2001 | 12:16 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Depends on how much you want for them. Email me or i'll email you for price.
[This message has been edited by eatmydust (edited January 18, 2001).]
Old Jan 20, 2001 | 02:12 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Your stock injectors are 19# Bosch, most likely. If you have your stock injectors I would recommend letting Rich at <A HREF="http://www.cruzinperformance.com/">Cruzin Performance</A> recondition them. It cost me less than 100 bucks for 8 injectors, a cold start valve, the Fel-Pro gaskets you need and shipping.
They then come back to you like new plus the are flow-matched and balanced.
Red 86 T/A 5.0 TPI (LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Polished Plenum ~ Runners ~ TB
~Polished Wheels ~ Alternator ~ Fuel Rail
~SLP TB Airfoil ~ Pirelli 245/50/16
~All Else Stock
Old Jan 20, 2001 | 06:16 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Putting in larger injectors won't do much good without recalibrating the PROM
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
My own prom (finally)
Old Jan 21, 2001 | 09:26 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with TC602. Unless you have modded your engine a fair amount you will just run overly rich without lowering your fuel pressure (partially effective) or alter the eprom.
On a basically stock engine, larger injectors will kill WOT performance.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
