AFPR help.
Old Aug 9, 2007 | 08:59 PM
bigjay89gta's Avatar
Car: 89 GTA
AFPR help.
I just installed a accel adjustable fuel pressure regulator and I cant adjust it. No matter how much I turn the screw it doesnt change. It is stuck at 38 psi at idle with no vacuum and 40 with vacuum. I think maybe I got a faulty AFPR. I mean I had it all the way down and it was at 38 psi I loosened it all the way and it hit 40. Anyone have a clue what the problem is?
Plus how does it work? Loosen higher pressure or lower pressure?
Jason
Old Aug 10, 2007 | 07:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: AFPR help.
Loosen - lower
Maybe you assembled the internals backwards.
Old Aug 10, 2007 | 11:21 AM
Car: 89 GTA
Re: AFPR help.
yeah I took it back apart and forgot to put the steel plate on top that the screw pushes on.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Numbah-1
Oct 2, 2015 08:27 AM
355tpipickup
Sep 4, 2015 05:32 PM
