injector clips
Old Aug 9, 2007 | 11:43 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
injector clips Wrong place?
well i posted a thread of a popping sound in my mufflers. And I know this might sound stupid but do the order of the injector clips matter? I mean what happens if you cross them left clip on right injector, and right clip on left injector? Will this cause that popping sound. And if it does matter, are they marked or something?, cause I did a TBI to TPI swap and in the process removed all the old wire loom that was no good anyway and cant tell witch goes on witch. Any help Please
Old Aug 10, 2007 | 12:27 AM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips Wrong place?
ANYBODY? help me I hate that noise
Old Aug 10, 2007 | 12:41 AM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
Re: injector clips
it shouldnt matter from what i rember TPI is a batchfire system and the injectors fire all at the same time.
the poping sound out the mufflers is probly a sign that you are running a tad on the rich side
Old Aug 10, 2007 | 12:55 AM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips
how would I fix that? my exhaust doesnt smell bad and there is no black smoke. Are there any other symptoms? Or can it run rich without smoke and strong odor?
Old Aug 10, 2007 | 07:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: injector clips
There are also lean pops. I had some of those last week.
TPI is batchfire. You don't need to worry about which plug goes on which injector. Impossible to mess up with the factory harnesses.
Old Aug 10, 2007 | 11:43 AM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips
Thanks man, so it doesnt matter huh? thats cool, now I just got to figure out why it is popping. Do you have any suggestions? Timing? fuel pressure? something?
Old Aug 10, 2007 | 06:24 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: injector clips
I thought "batch fire" meant that 1 bank of injectors, right or left, all fired at the same time. I think the connectors for each bank have a different color-code on the two wires. I don't think you can cross the connectors right to left and have the engine running correctly.
Bill
Old Aug 10, 2007 | 06:25 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips
Do you have more info on that? really interested
Old Aug 10, 2007 | 06:49 PM
Burnout91's Avatar
Engine: Modded L98
Re: injector clips
OK, I just looked. On my '91 L98 each injector (connector) on the right side has one GREEN and one pink/black stripe wire. Left side has BLUE and pink/black stripe. Factory original.
Bill
Old Aug 10, 2007 | 06:52 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips
right and left, you mean from outside car or inside car?
Old Aug 10, 2007 | 07:19 PM
Burnout91's Avatar
Engine: Modded L98
Re: injector clips
That color-coding also checks-out with the factory Chevrolet Service Manual. Left = drivers side, Right = passenger side.
Bill
Guest
Guest
Posts: n/a
Re: injector clips
Yes there's different wires to each side, and no it doesnt make any difference whatsoever where you hook them up.
Old Aug 10, 2007 | 07:30 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips
my injectors are reading 18.5 ohms. is that bad?
Old Aug 10, 2007 | 11:38 PM
blackbird615's Avatar
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
Re: injector clips
nope, they should be anywhere between 14-17 ohms of resistance. 18 is fine.
however, your injectors could be bad and still read the right amount of ohms. an ohm test only reads the electrical resistance in the injector. it doesn't read whether or not the injector is clogged or spraying evenly.
Old Aug 11, 2007 | 02:12 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: injector clips
so how do i find out if they are leaking, clogged, or spraying wrong?
Old Aug 11, 2007 | 03:52 PM
Engine: 305TPI LB9
Axle/Gears: Hmm
Re: injector clips
you could send them to get flow tested. i can't remember the name of the one popular injector guy on here you could send them to, but can anyone else chime in?
Old Aug 12, 2007 | 07:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: injector clips
A fuel pressure test will tell you if they're leaking.
I think the guy's name is Rich at Cruizin Performance that does injector cleaning and flow matching.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
