High-flow TPI Camaro air lid
Old Oct 21, 2010 | 12:54 AM
  #201
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: High-flow TPI Camaro air lid
Hey 1bad91 sorry if I missed this but overall did you raise the lid about a good 1/2 inch?
It's raised from 3/8" to 1/2" on the bottom side. The pics on page 1 explain it a little better.
Thank you. I will talk to you about it next summer.
Welcome!
Old Oct 29, 2010 | 04:08 PM
  #202
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I decided that I had to give this a try. I first built my ram air boxes and those turned out so well that I decided to move ahead on the air lid. I opened it up, leaving the leading edge of each filter cover housing attached and used my heat gun to soften the plastic and spread the body of the lid, adding 1/2 " at the thinnest point.
I visited a local plasitc supplier and purchased remnants of 1/8" and 1/4 " plastic and two part acrylic adhesive. I didnt buy the cartridges or the mixing gun. Im only making one box and didnt feel the purchase made sense.
Ive just now sealed up the front portion of the lid. When the glue dries, Ill start on the back. So far it looks like it will turn out fine. Still need to get a 3 1/2" pipe coupling (4" od) from the hardware store.
Old Nov 8, 2010 | 02:13 PM
  #203
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Im almost done with my lid. This was alot of work and a bit scary since you have to virtually destroy the OE lid to make the hi flow peice. Once you start, there's no turning back. Several hours over several days, $80 in materials, and its finally about there. I followed Ibad91's design with a bit of modification. BTW, I should have said 3" PVC pipe coupling. Mike said he gets his at Lowes. I had to go to an irrigation supplier and pay $9 for it. No hardware store had 3" PVC.
At any rate, Im excited to be getting it done. I am pleased with how its come together. For other's edification, if you have the money, its well worth $300 to purchase the peice from Mike. In hindsight, while I love to build things like this, I would say its almost not worth it when you can have one made for such a reasonable price. I can say from experience, Mike's not making much on these boxes. Not for all the time it takes.
Cant wait to see the results. Putting my wide band AFR monitor together now and have the laptop ready to go with my CALMAP software. I know that this air lid, along with the ram air, will require changes to my base fuel map to compensate for the addition air at higher speeds. Almost wish I had MAF right now but I think I can make this work since the additional air will result in an increase in MAP for which I can adjust accordingly. Just have to make some runs to find out.
Old Nov 8, 2010 | 04:48 PM
  #204
thegooseman's Avatar
Car: 1992 RS
Very nice. Did you take pictures of your lid through the process of building it?
Old Nov 8, 2010 | 06:02 PM
  #205
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Making custom parts does take time along with the materials and tools. A number of people do not realize the time and effort that goes into it. I agree in that $300 is probably well worth it.
Old Nov 9, 2010 | 01:26 AM
  #206
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
lol ! Yea it's true, for the time and materials it takes to make each one, I really dont make much more than fast-food wages!!
I use the 4 inch coupler on mine though...
Hope yours turns out well!
Mike
Old Nov 9, 2010 | 04:55 PM
  #207
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
4 inch?! I went by your picture! Lol. At any rate, the peice I got was 4" od and it fits the 4" silicone hose perfectly. I just applied the first coat of paint and Im waiting for it to dry. It wont look nearly as clean as yours but Ill be proud to display it at the local car shows this coming summer. Got my Moroso vacuum pump back yesterday too. Now a little fuel line work and waiting for my brakes to get here from Fly N' Bye. Very exciting. Oh boy, oh boy!
Old Nov 9, 2010 | 05:10 PM
  #208
Car: 1989 GTA
Engine: 369 TPI
"24lb bosch @ 70 psi"
What setup are you running to get 70 psi fuel pressure? I am hoping to get 55 psi out of mine when I crank up the adjustment.
Old Jul 3, 2011 | 05:31 AM
  #209
Car: 1992 RS
Originally Posted by 1bad91Z
Thank you for the compliment!
I don't have any more cores to make one for you. I would need your lid to modify.
Also, I won't have the time to do so until summer of next year. (I have a full time job, part time job on the weekends, and part time college student). I don't take summer courses, so if you can hold out until then, I may be able to make one for you.
Well Its next year. Will you be making the lids again?
Old Jul 3, 2011 | 01:35 PM
  #210
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Dont know if I'll be doing anymore of them.. the price of materials to make them has gone up and I dont have any more stock lids to make them with. If someone REALLY wants one, we can talk over PM, but currently I dont have any plans to make anymore.
Old Jul 3, 2011 | 01:58 PM
  #211
Car: 1992 RS
Ok. I just got my new engine running and this looks like it would compliment it quite well. I tried to copy what you did before but failed miserably.
Old Dec 13, 2011 | 09:55 AM
  #212
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I was talked into building another one, it's about 70% complete. I should be finished with it before Christmas. Due to the holidays, this will be the last one I do this year. I will post pics when complete.
Happy Holidays!
Old Jan 22, 2012 | 12:34 PM
  #213
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
im building one of these for a tgo so cal tpi member. did you ever dyno the car to see any minor improvements?
Old Jan 23, 2012 | 08:42 AM
  #214
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I shipped the one I was working on a week or two ago.. Enjoy Brian!
I may also have another one available soon.
As far as dyno results, I haven't got any numbers back from the ones I've built, but there are some that picked up some ET and mph in the 1/4 with the high-flow lid. I definitely noticed a gain on my car.
Good luck!
Old Jun 25, 2014 | 09:22 AM
  #215
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I have a high-flow lid with connecting tube available if anyone is interested. This is one I built awhile back for one of my personal cars that I sold. I will not be building anymore due to material cost and lack of free time. PM me if you are interested!
Old Jun 25, 2014 | 04:33 PM
  #216
86IrocLewie's Avatar
Car: 1986 IROC-Z
Transmission: 700R4 2800 Stall Converter SftKit
Axle/Gears: 3.73 Strange Engineering 12-Bolt
I haven't been on the boards in awhile - got busy with life and a new house. But, I saw this post in my e-mail, and I wanted to chime in. I got one of these lids a few years back and can attest to the quality of the lid. I'm really glad I got one instead of attempting to make my own, and 1bad91Z is a knowledgeable guy and a great person to work with.
Old Jun 26, 2014 | 09:07 AM
  #217
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
THanks Lewie, I hope all is well with you and the family!
For those that requested pictures: Yes it is identical to the others I have made and I will post pics soon.
Old Jun 29, 2014 | 04:28 PM
  #218
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Here are the pics as promised. This is the last opportunity to own one of my lids as I will not be fabricating anymore of them.
pic lid3 shows inside the connecting sleeve with the aluminum insert down to the 4 inch inlet of the lid.
The lid comes with the sleeve and clamps. (Everything you need to connect it to the throttle body).
Enjoy!
Attached Thumbnails High-flow TPI Camaro air lid-lid2.jpg   High-flow TPI Camaro air lid-lid3.jpg   High-flow TPI Camaro air lid-lid1.jpg
Old Jul 3, 2014 | 10:08 AM
  #219
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It's for sale. Posted it in classifieds.
https://www.thirdgen.org/forums/engi...w-tpi-air.html
Old Jul 3, 2014 | 02:35 PM
  #220
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Sale pending..
Old Jul 11, 2014 | 11:00 AM
  #221
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
SOLD..
Old Nov 13, 2014 | 09:48 PM
  #222
RJ76FLORES76's Avatar
Car: 1991 Camaro Z28
Engine: 5.7 L TPI
Are you making any more
Old Nov 16, 2014 | 04:27 PM
  #223
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Probably not.. There is a slim chance maybe after first of the year but that depends greatly on work schedule. I will post here if and when I do make another.
Old Nov 16, 2014 | 05:51 PM
  #224
Engine: 5.7 L TPI
I like what you did and I doubt I could make it look as good as you did
Old May 22, 2015 | 12:40 AM
  #225
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
BUMP since this is information that can help. I really can't believe a bigger Air Lid was never moreso mass produced
Love the Idea, I'm going to have to try and do something like this for my engine soon, And somehow get a bigger maf as well since I am not fully enticed by the idea of switching over to Speed Density.
Old Apr 7, 2016 | 04:23 PM
  #226
Matthew1821's Avatar
Car: 1992 Camaro Z28 25th Anniversary
If anyone happens to make a spare Lid. Shoot me a pm and ill buy it right away
Old Dec 25, 2016 | 01:45 PM
  #227
82IMSA's Avatar
Car: 1986 Camaro IROC Z28
Engine: LS7
Transmission: Built 4L80e w/GearVendors overdrive
Any chance I could get you to make one of these for my LS7 swap? Do you think it will flow enough air for that beast? I can supply the stock air box from my 1986 IROC Z-28 for you to mod.
Would need to attach to a MAF housing like this one https://www.amazon.com/Spectre-Perfo.../dp/B003J9IXT4 Might even need to install this in place of the PVC fitting or there may not be room for the MAF? I haven't got the motor in the car yet to see how much room there is.
https://www.thirdgen.org/forums/ltx-...into-86-a.html
Old Dec 31, 2016 | 10:26 AM
  #228
skinny z's Avatar
Something to consider:
The air box holds two filters. Each with an area of about 36 square inches for a total of 72 square inches.
K and N specs the following for filtering requirements: Area = (CID X RPM) / 20 839
If your LS7 (at 427 CID) revs to 6000 RPM then 122 square inches of filter media is required. Clearly, there is not enough filtering media to support the expected air flow requirements.
Yes, we all know Joe or Sally who has a 700 HP engine running through a tiny filter and they are just fine. Kind of makes you think what their results might be if they had a properly spec'd air filtration system doesn't it?
Old Dec 31, 2016 | 12:19 PM
  #229
82IMSA's Avatar
Engine: LS7
Thanks! That's exactly what I was looking for. LS7 red line is actually 7,000 rpm, so (427 x 7,000)/20,839 = 143.43 meaning I need about double what the car comes with. Doing the math on the stock engine, those filters were perfect if you kept it under 5,000 rpm. Back to the drawing board. Going to need to fab a box that can hold two 72 sq in filters in the stock locations. More fiberglass work...
Old May 23, 2018 | 11:11 PM
  #230
Dscott's Avatar
Car: 89 Iroc street car
Engine: Fitech vortec 400sbc/T5
Transmission: Also 69 Chevelle, Nascar chassis
Axle/Gears: 700hp roadrace track day car
Any updates here?
Old May 24, 2018 | 07:31 AM
  #231
skinny z's Avatar
I can't find the thread at the moment however another member here has successfully fitted a pair of cone shaped filters beneath where the stock filter elements would normally be. Installation looked pretty slick and needed a few pieces of ABS plastic to adapt the cone filter bases.
Old May 24, 2018 | 07:43 AM
  #232
skinny z's Avatar
Found it.
https://www.thirdgen.org/forums/ltx-...to-86-a-3.html
Old May 15, 2019 | 12:05 AM
  #233
Dscott's Avatar
TTT
Old Mar 14, 2023 | 04:28 PM
  #234
aggie3rdgen's Avatar
Car: 1986 Camaro Z28
Engine: 6.0L LS
TTT... If anyone's had success making these, I have a core lid and we could work a price. Or if anyone is interested in selling a spare, PM me.
Old Mar 31, 2025 | 08:45 PM
  #235
Nsty_6.2's Avatar
Car: 1989 Chevy Camaro
Engine: 6.2 376l LS3
Transmission: 4L80E 3k stall
You wouldn't happen to have one for sale would you?
Old Jun 3, 2025 | 06:42 AM
  #236
Nsty_6.2's Avatar
Gonna start making these
Attached Thumbnails High-flow TPI Camaro air lid-thumbnail_image5.jpg   High-flow TPI Camaro air lid-thumbnail_image6.jpg   High-flow TPI Camaro air lid-thumbnail_image7.jpg   High-flow TPI Camaro air lid-image8.png
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
