What fuel pressure???>>
Old Jan 20, 2001 | 05:54 PM
98_1LE's Avatar
I am about finished installing an adjustable fuel pressure regulator on the Formula. What pressure should I set it at? It is a basically a stock L98. Mods are: ported plenum, screens out of MAF, Hypertech Thermomaster chip, SLP 2OTL muffler/yailpipes only (the rest of the exhaust is stock), airfoil, 160 stat, relocated MAT & TCI Breakaway torque converter (rated 2200 rpm stall, actual 1800 rpm foot stall on drag radials). What gains should I expect?
Thanks,
Chuck
87 Formula 350 14.61@94.07 before 2OTL, TCI stall, Nitto's, tubular LCA's & panhard
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Jan 23, 2001 | 01:26 AM
Ski89Z28's Avatar
Setting it between 42 - 47 psi is usually what they tell you to set it at. As for gains depends on the car and mods but I think I remember TPIS hints book said between 10 and 20 HP. But like I said more mods the more HP to a point.
The best way to set it at the track. Make a run then adjust it up 1 to 2 psi and run it again and see if your time is better til it isn't.
Good Luck!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Old Jan 23, 2001 | 06:45 AM
Kyle F's Avatar
Well you dont need to take your pressure to high or it will run rich. You dont have that many mods.44-46 would be my guess on a range for it.
This is surely going to lead to the "You need a custom Prom if you want to cahnge your fuel pressure" So here is my take on it. You have done some mods so you are flowingm ore air so you can use a little more fuel, and is a HELL of a lot cheaper than a new computer chip.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's ..... **** on Monkie
SOON TO BE A SUPER CHARGED TURBO WITH NOS ON A 500000 CU. IN engine
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
