afr heads worth every penny jus finished install
i jus installed my 195cc afr heads on my 355 tpi and let me tell ya they are WORTH every penny i highly recommed them car really plants u in seat now install was easy these heads ade a work of art the cnc pork work is awesome get them u wont be disappointed any questions jus e mail or reply here thanks mods in sig
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hopeing for 12's
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
How did you get the runners on the intake to match up with the heads? I have been told that there is a difference in runner height by an AFR technician. I ordered the 190's because he told me the 195's won't match the Edelbrock base's runners. Did you modify your runners on the intake?
[This message has been edited by MikeC.86Roc (edited January 25, 2001).]
nope i didnt have to modify anything at all everything lined up perfect i heard the same thing u did after i bought them new from a guy on ebay scared me but install went great no probs at all and i got my car out yesterday and WOW AND I MEAN WOW!!!! best mod afr kicks a$$
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
How much compression are you pushing with 58cc heads in a 355?? You gotta be close to 11:1 if not over that!!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, pocket ported 64cc or 76cc heads(undecided), ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
i figure im right at 10.9 to 1 and i cant hear any spark knock and my auto x ray isnt showing any timing retard it feels awesome!!!!!1
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
