what fuel pressure should i run with a 305?
Old Jan 27, 2001 | 08:27 AM
Artic White Z's Avatar
i got a 91 z with a 305. i did all of the small mods to it. the largest one was the whole exhaust system. i have a fuel pressure regulator and im not sure where to set it at. what should the pressure be set on?
Old Jan 27, 2001 | 09:33 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
My 92 305 TPI, when I still had the 305, the stock PSI for mine was 42 psi. My car ran best however at 44 psi. Really its different for every car. For example: everyone told me to run my fuel pressure at 47 to 48 psi so I did and it started back fireing on me so thats when I turned it down till I got the best power/economy at 44 psi.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
Old Jan 27, 2001 | 09:50 AM
theformula's Avatar
Leave your FP stock
91 Formula
305 TPI 5speed
1LE/G92/WS6
w/91 GTA rims,hood,gfx,tailights
Cold air ind. w/K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
