Im a happy man today!
Old Aug 13, 2007 | 03:42 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
I pulled of my TPI intake manifold in about an hour ( i heard it could be a nightmare)
no bolts seized, only one was really in there and i got it.
Also found it got a roller cam ( previous owner was a hack) i thought he may have swapped a older block in ( Self aligning rockers + roller lifters! ) means its Original, mostly, still could be a 305.. but im happy
If u guys want i can take pics as i start to pull the waterpump etc, and then pull the cam out
anyway, IM HAPPY i didnt have any problems so far!
also, any advice for when i put the intake back on as far as putting sealant on the threads etc
thanks!
Old Aug 17, 2007 | 08:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Im a happy man today!
Put sealant with Teflon on all the bolts. Some don't go into water jackets but bah.
Old Aug 19, 2007 | 09:19 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
another question
at a minimum what do i need to run this cam ( zz4) because ive been reading after .460 the valve seals die. I dont care about that at this point... Im worried about my valve hitting the piston at .510 with stock springs and rockers will they?
And if so do i only need springs to prevent this?
Old Aug 20, 2007 | 08:01 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Nothing guys? im going to be starting this motor within the week
Old Aug 20, 2007 | 10:46 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Stock springs are only good to .450 lift on both sides (intake and exhaust). You need to upgrade springs/locks/reatainers to go with a .510 cam if you plan on your motor living awhile. Get the correct matched cam kit from Comp to match your cam.
Old Aug 20, 2007 | 11:14 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I have been running the ZZ3 (ZZ4,same thing) cam with stock heads and stock shortblock for years of "spirited" driving. With the cam installation I installed ZZ3/ZZ4 valve springs to prevent coil bind. While rotating the motor BY HAND, I had valve guide to valve keeper inteference. Instead of getting the valve guides machined to eliminate the interference, I (gasp) trimmed the bottom edge of the keepers (~.02"-.03"). I know it's not the correct method, and yes I did have nightmares about dropping a valve, but 30K miles later and a few trips 6200 RPMs, no problems (maybe I should say, 'Don't try this at home'...). Nice cam, decent gains.
Bill
Old Aug 21, 2007 | 06:00 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
what exactly do you mean motor living a while
i wont have valve to piston interferance will i?
Id probly end up running it for a few days before the springs came etc
Old Aug 22, 2007 | 01:26 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You will experience valve float until you change the springs. Just wait to drive it until the springs get installed.
Old Aug 22, 2007 | 05:45 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
alright cool ty
Old Aug 22, 2007 | 06:58 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
intake manifold is on and torqued down
Just gotta tighten the power steering pump and the front accessories and then wait for my fuel injectors
Old Aug 22, 2007 | 07:11 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
whats .510 i thought the zz4 cam was .477 or so lift?
Old Aug 22, 2007 | 08:03 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
.510 on the exhaust, the intake is around .477 i believe
bjpotter
Oct 4, 2015 07:48 PM
paul_huryk
Oct 1, 2015 04:27 PM
