305 heads
Old Jan 26, 2001 | 10:11 PM
Dan W's Avatar
305 heads
Who here has pulled 305 TPI heads and found them to be the swirl port castins?
If you dont know what I'm talking about by swirl port, they have a cast ramp around the valve guide instead of the standard style valve bowl.
Old Jan 27, 2001 | 12:00 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
never seen one do you have a pic?
Old Jan 28, 2001 | 04:48 PM
MrJ's Avatar
MrJ
I haven't pulled my car's heads, but I did pull a valve cover and got the casting numbers of the head, and it's a '081' head, non-swirl.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Jan 29, 2001 | 03:51 AM
Dan W's Avatar
No pics on hand... I might be able to get one next week for ya if I borrow a buds digital camera.
Old Jan 29, 2001 | 03:59 PM
Guest
Guest
Posts: n/a
I looked at the heads on the 91 TPI engine I have before I put it in the car, and they werent swirl port heads. Dunno what the number was.
Old Jan 30, 2001 | 07:59 PM
MrF-body's Avatar
i swapped a 305 in an 87 iroc-z last year, the heads on it were swirlys.
Old Jan 30, 2001 | 08:57 PM
Dan W's Avatar
Just want to clairify... We are not talking about a fast burn combustion chamber here.
We are talking about something you can only see if you remove an intake valve. MrF-body, did you remove an intake valve?
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
