I have the opportunity to pick up an Edelbrock Performer Intake w/ EGR & Throttle Body for around $100, with very little miles (under 500) on it. My question is, is this worth it? Am I going to notice a serious power increase? My current list of modifications are listed in my signature. Thanks.
Adam .R - 1992 25th Anniversary "Heritage" Camaro Z28 5.7L 350ci - SLP Intake Runners, SLP 58mm Throttle Body, SLP Catback Exhaust, SLP Crank Reduction Pulley, SLP Custom PROM Chip, SLP Shift Improvement Kit, SLP Flow-Booster Airfoil, SLP 160 Thermostat,GMC "Syclone" Fuel Pump (90psi), Accel Fuel Pressure Regulator (38psi), Richmond 4.10 Gears, BMR Lower Control Arms,
If it's the Hi-Flow for TPI SNAG IT! $100 is a steal on a $300 intake. Intakes don't wear out, so the physical appearance does not matter. As long as its not cracked or a corner broken off. Even stripped bolt holes can be tapped or heli-cored.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
