super ram
Old Jan 25, 2001 | 01:28 PM
92formula's Avatar
Car: 1992 formula WS6
Engine: none
super ram
Where do you get a super ram,and what does it included.
Old Jan 25, 2001 | 06:36 PM
Blade's Avatar
You buy it from Accel and you go to their website to see what's included
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 26, 2001 | 11:35 AM
92formula's Avatar
Engine: none
What is accel website??????
Old Jan 26, 2001 | 11:46 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You can start by going to www.mrgasket.com and select Accel on that board.
To the best of my knowledge the Superram comes with:
top plenum box
top plenum box cover plate
gasket for above
short nearly 90 degree runners
gasket for above
runner to manifold bolts
runner to plenum bolts
plenum cover plate bolts
some plugs and fittings
new throotle cable mounting bracket
brake vacuum hose (I think)
instructions
You should get a complete kit for your installation.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Feb 2, 2001 | 12:13 AM
tastedapain's Avatar
I GOT A SET UP THAT WILL SMOKE THE SUPER RAM....I DROPPED 4 TENTHS WHEN I SWITCHED FROM SUPER RAM TO MINI RAM.....LOOK IN THIS SECTION FOR MY AD.....FEEL FREE TO ASK ANY QUESTIONS...LATER!
Old Feb 2, 2001 | 03:16 PM
Blade's Avatar
Dude u're an idiot... go away.
Old Feb 2, 2001 | 03:33 PM
theformula's Avatar
lol blade
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
