Where are the mass air sensors on a 86 IROC???
I have replaced the 2 air filters with k'n filters but where are those sensors that everyone takes out??...in that black plastic circle going to the intake???I see some stuff in there...is it safe to take out..is it worth it???Oh yeah it is a 86 LB9 305 tpi
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,2:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER CD RECIEVER WITH REMOTE AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
The mass air flow sensor is located between the air filters and the throttle body, so yes the round black thing with the wiring going to it. You can not just remove the entire mass air flow sensor (unless you convert to speed density using a MAP sensor) which is quite not something you should do unless you have experience.
What I suspect you are referring to is the removal of the screens on the mass air flow sensor, which can easily be done. The pro's and con's of doing so are debateable.
eightsixseven
Dec 16, 2024 01:50 PM
mustangman65_79
Aug 11, 2015 03:17 PM
