Edelbrock hi flow problems
Old Feb 1, 2001 | 06:28 PM
Aaron's 87's Avatar
I've heard of the fuel rail problems some have had with the Edelbrock Hi Flow base. I'm wondering if I have the same thing. I cannot put the runners on with the fuel rail bolted down. I asked Edelbrock about using the supplied 4 washers to raise the fuel rail, but they are for something else. Any ideas?
Old Feb 2, 2001 | 07:42 AM
Aaron's 87's Avatar
HELP
Old Feb 2, 2001 | 07:58 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
What you will need to do is get the fuel rails in place, with the bolts in, and let them sit like that. Then bolt the runners on. After you are all done then you can bolt the fuel rails down. That's what I had to do on my 91 Z. Just take your time and things will start to come together.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Feb 2, 2001 | 08:22 AM
vettenuts's Avatar
I found it, check this out:
https://www.thirdgen.org/messgboard/...ML/000195.html
1990 Roadster
Old Feb 2, 2001 | 01:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have no problem with my fuel rails but I did have a probelm bolting the cap on the distributer. The screw was going thougth the hole and hitting intake thats how close it comes. But my car doesnt run now and I have no idea why
Old Feb 2, 2001 | 01:17 PM
Aaron's 87's Avatar
I saw that post, but Edelbrock says the supplied washers are for the coil, not the fuel rail. I could loosen the fuel rail and put the runners on, but I'm an a$$ and I think things should work the way they promise. So now, I'm edelbrock's problem.
Old Feb 2, 2001 | 02:15 PM
Scott C's Avatar
This is great news...I hope I don't have the same problem with the brand new Edelbrock Hi-Flow base & runners I just received! I'm expecting a fuel rail any day now, so the first thing I'm going to do is test fit it and see if I have the same problem as you.
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 roller rockers, Edelbrock Hi-Flow base, runners & 52mm TB, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Feb 3, 2001 | 09:38 AM
Scott C's Avatar
So I test fit the Hi-Flo base, runners, tb and plenum and I see that I'll need to grind a bit of material off one of the runner tubes at the bottom just to be able to bolt it up. Cool...(is there a specific left/right side runner?). Also, did you guys receive a set of runner to plenum gaskets or just the lower gaskets? What gaskets am I supposed to use for the large tube runners and a port matched plenum? They also jipped me on the pipe plugs that were supposed to be included witht the base according to the instruction sheet! Just couldn't take the extra 5 seconds and toss those required parts in the box, could they! Dammit...
Old Feb 3, 2001 | 10:12 AM
Aaron's 87's Avatar
Two people at Edelbrock have said that they've never had any problems with the setup or heard of the low fuel rail problem. I'm kicking myself for not going to a four barrel intake with a new TB. Would've cost less and performed better.
Just got the lower gaskets too. You'll have to get a set of stock uppers and cut them out, or some aftermarket places sell bigger ones I'm told. What pipe plugs are you talking about? Left vs. Right depends on your year. Pre 89 has a hole for the cold start injector on the driver's side runners.
[This message has been edited by Aaron's 87 (edited February 03, 2001).]
Old Feb 3, 2001 | 11:40 AM
87IROC350's Avatar
Engine: 5.7
I got my Edelbrock base last fall and installed it over winter. I have the SLP runners so I always have had to loosen the fuel rail a little bit to get the runners to fit in place.
The problem I had when installing the injectors on the new base is the supports that the fuel rail bolts into was too short. This caused my injectors to bind. I have heard other people complain that this caused their injectors to stay wide open causing their car to run extremely rich. I identified the problem before I had the entire intake together by trying to move the injectors. On my stock intake I could move the injectors back and forth slightly. On the new Edelbrock base the injectors would not budge because the bottom of the injector was being forced into the intake casting causing it to bind (with the fuel rail bolted down). I ended up buying four washers and installing them between the fuel rail and base. This took the bind out of the injectors and allowed some back and forth movement on the injector.
Oh ya, the first time I received the Edelbrock intake from Summit it was defective because the hole that is drilled for the EGR bolt went all the way through the runner passageway. They sent me a second one and I there was no problem except for the fuel rail height.
I'd be more concerned about the injectors seating properly. My .02. Hope that helps.
Brian
Old Feb 3, 2001 | 01:35 PM
rondubbs's Avatar
hey guys i am one of the first people to have this problem, edelbrock is full of **** saying that they never heard of it becasue i personally spoke to them many times... anyway to diagnose it real easy, just put on a fuel pressure gauge and turn the key on, if the fuel pressure goes up and then immediatley goes to 0 then your injectors are binding , so put some washers under the fuel rail bolts.. if the pressure stays then you are fine.. good luck guys and FUC-K EDELBROCK and their horrible casting methods
[This message has been edited by ron rizzotti (edited February 03, 2001).]
Old Feb 3, 2001 | 02:34 PM
Aaron's 87's Avatar
The engine's not in the car, so I can't check the fp yet. I wanted to figure this mess out before I started it up. Maybe I can use a mirror to look at the injectors in the manifold runners and see where they're at. Plus, now you got me thinking if I checked the runners for overdrilled holes. Where's that mirror on a stick?
Old Feb 3, 2001 | 05:56 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Hmm?!? I didn't have any of the problems you guys are talking about except one: I didn't get all the plugs for unused holes. Everything bolted right up, I thing I got the gaskets, but am not sure if they came with the the base or the AS&M Large tube runners ( I test assembled everything and put it all back in a box where it sat for 4 months before installation).
Good luck and I hope everything works out for you guys.
Sparks a flyin'
Old Feb 4, 2001 | 07:28 PM
Aaron's 87's Avatar
The injectors are frozen with the rail bolted down, so how far do I raise them? Just enough to let them rotate, or higher?
Scott C, where'd you have to grind?
Old Feb 4, 2001 | 07:53 PM
rondubbs's Avatar
aaron, i had to put 2, 1/8 inch washers under each bolt
Old Feb 4, 2001 | 09:23 PM
DSouthern's Avatar
Aaron's 87
I also had this injector binding problem with my edelbrock intake and Ron and I sent several e-mail to each other getting this sorted out.
87IROC350 describes the same problem I was having.
You want to get all the injectors to set down in the intake the same amount. On mime I used thicker washers under the driven side fuel rail than on the passengers side, so that all the injectors had the same fit. You will just have to eyeball this and use a little common sense. You can unbolt the fuel rail and change washers pretty fast so it shouldn't be that big a deal.
I used the stock runners with my intake and had no problem with them bolting up.
Old Feb 4, 2001 | 09:44 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I've been following your guy's post because I'm putting an Edelbrock base on my new engine. I don't really understand what you mean by the injectors binding. Can someone please explain this.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 4, 2001 | 09:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
ok mine is running good now. i didnt have any problems with the fuel rails. Only problem I had was bolting the inside bolts on my AS&M Runners.
Old Feb 5, 2001 | 07:46 PM
Scott C's Avatar
Nobody had to grind the material at the bottom of the #5 runner? Mine won't even bolt up unless I take about 1/8" of material off! It rubs on the edge of the Hi-Flo base.
Old Feb 5, 2001 | 09:09 PM
DSouthern's Avatar
Paul,
Read 87IROC350s reply just a few up, it explains the injector binding problem in detail.
The way I noticed this on my intake was when I went to hook up the injectors connectors. On the driver side I couldn't get the connectors on the injectors because they were binding in the intake and I couldn't turn/twist them to get the connectors attached.
Old Feb 5, 2001 | 09:12 PM
rondubbs's Avatar
scott i had to grind down some of my edelbrock driver side runner becasue it was rubbing against my back injector.
92camaroJoe
Jul 29, 2023 07:57 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
