Best place for 2nd fuel pump?
Old Feb 4, 2001 | 08:42 PM
theformula's Avatar
I have a Bosch in line fuel pump I need to install. Wheres the best place to install it?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 8, 2001 | 01:34 PM
RedRaider88's Avatar
Best place we have found so far is under and behind the rear-drivers-side seat. It will actually mount under the car with the pos. and neg. terminals of the pump pointed directly at the pumpkin on the rear-end. No problem with clearance and the fuel lines and wires are all right there. Not sure how to post a diagram or I would. Hope it helps.
1988 Trans Am. Carburetor fed LT1. T-5. Ready to rock and roll. No runs yet though.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
