Accle Super Ram VS HSR
Old Aug 24, 2007 | 03:23 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
What are the pros cons of each VS the other?
Old Aug 24, 2007 | 08:01 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Accle Super Ram VS HSR
This site has some interesting data you might like...
http://stealthram.com/intakecompare.html
Hope this helps!
Old Aug 24, 2007 | 10:31 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
One drawback to the Super Ram is that it is no longer in production. I found out after Lingenfelter Performance let me order one. Maybe some performance parts dealer has one, somewhere, or you have to find a used one.
Bill
Old Aug 27, 2007 | 09:53 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
SuperRam retains the EGR, good midrange torque, hard to install, looks great.
Holly has no EGR, better pull up top, easier to install, not so pretty.
I have a SuperRam, but I sure wouldn't want to take it off and back on for mods later on. I see you already have heads, cam, so you're probably looking for something that's more of a permanent install?
BTW, send me some pics of the Formula if you have some. mr6spd@gmail.com
Old Aug 27, 2007 | 10:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Bill
That is a bummer! Scoggin Dickey was selling a complete crate EFI engine using the SuperRam. I guess they'll have to change that, now.
Old Aug 27, 2007 | 11:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
pretty much sums it up... i think the Superram is nice looking but the HSR is also pretty nice as well. It has grown on me and now i like it, especially after painting mine.
HSR is easy as pie to install. it was 10 times easier than TPI, and TPI is alot easier than superram. that was the only draw back to the superram other than the fact it was more expensive than HSR. It was too damn PITA to install.
And the price...UESD superrams for 600-700 dollars. You can get a NEW HSR for 550 or so now from summit.
Old Aug 27, 2007 | 11:41 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
the superram is a very sweet intake one installed with enough bolts to build another car with!but it WORKS!!!!!
stealthram very cool looking intake especially polished,easy to instal and if you are good you can instal an EGR valve into it.not hard at all especially if you have worked with the vette egr system,C.A.R.B. legal well no but will it get by the smog ****'s prolly!
Lt1 intake easy to mod for conventional instal looks cool and is cheaper than all but thats a totally different story.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
Dragonsys
Sep 25, 2015 03:51 PM
