Simple fuel rail question
Hi guys,
I don't have a TPI car, but a friend of mine does and he wanted me to post up a question for you (He's not too good with fuel injection):
He just called me up to ask which port on the fuel rail is the feed line, and which is the return. I believe that the top line is feed, and the bottom is the return, but I just wanted to make sure before I call him back.
Thanks!
Thanks!
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: Simple fuel rail question
The fittings are two different sizes (14mm and 16mm I think) with the larger being the inlet. It is also the fitting on top when you're looking at the two hard line extensions that come out by the front of the drivers side cylinder head.
