Vortec heads vs. L98 heads...
Old Feb 9, 2001 | 09:43 AM
RoadRocket L98's Avatar
In a recent issue of Car Craft, they tested different heads on a 383 on a dyno. I believe the Vortec heads outperformed the L98 heads by around 40hp, not sure about torque. This was on a carburated engine with a manifold designed to work with the Vortecs. Will Vortec heads bolt right up to a TPI intake base? Does anyone have any information theyd like to share on the Vortecs?
'83 Firebird 2.8
'89 Firebird Formula 350
2nd owner, red/grey, t-tops, dual cats, and a 3.27:1 rear
K&N, TB bypass, No MAF screens, CAI, full Accel ignition
Old Feb 9, 2001 | 10:22 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
the archives are packed. search under your topic heading.
Old Feb 11, 2001 | 11:35 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
yes, but you have to buy vortec heads specially made to accept standard SBC intake bolt patterns which is like $50 more or something
Old Feb 11, 2001 | 11:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm moving this to the TPI board after I reply.
Neither the Vortec heads nor the L98 heads will "bolt right up" to an f-body intake manifold. They have a different intake bolt pattern. The Vortec heads also have a different intake port shape that doesnt line up. 85-86 TPI F-body intakes and 85-91 Corvette intakes will work with the L98 aluminum heads, they have the same bolt pattern. But you're better off getting an aftermarket TPI intake manifold like from Accel, TPIS or Edelbrock. Scoggin Dickey is making a TPI intake for Vortec heads, but it wont be available until later this year. Also, neither heads have EGR passages, so if you have emissions testing in your area that will be a problem.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
