Guess what I found!!
Old Feb 12, 2001 | 03:57 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
After about my 8th tank of gas while getting only about 10mpg, I started poking around.... I was wondering why I would get this strong fuel odor every time I turned on my fan, so I started looking at the cold start injector boss and saw fuel stains around the union and a little bit up on the fuel rail..... reached down in there with my fat fingers and found I could turn the boss with one finger!! The darn thing had worked it's way loose I guess when I was moving the cold start injector while I was putting the driver's side runner back in after I powdercoated the intake. I tightened the thing almost 2 complete turns!! I know I should have went ahead and changed the O-ring but I didn't feel like taking off the runner and all that just for a stinkin o-ring. I'll keep my fingers crossed and see if this does the trick....
One good thing, I noticed before I tightened it that when I shut off the engine I could hear a slight hissing sound.... now it's gone........
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old May 14, 2005 | 01:11 PM
Vader's Avatar
Discovered any more leaks on the vehicle there. Chief?
Old May 14, 2005 | 04:56 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Another 4 year old post Vader, what are you doing? Digging up the very first posts people made?
Old May 15, 2005 | 01:32 AM
Vader's Avatar
Well, not exactly. But have you noticed if the TPI board page is loading up any faster?
Old Jun 17, 2005 | 02:36 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I am having a problem with starting my car cold and keeping it running when cold, when it is warm it runs great. My car is a 85 TA TPI I know that it has a cold start injector. I just dont know how to diagnose if the injector is bad or what, Vader is there anything I can do to diagnose what the problem can be, I have done most of the obvious and some other things too. I was also thinking it could be the IAC except if it were the IAC wouldent it not run good warm too?
thanks,
Dennis Pope
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Stryker412
Sep 7, 2015 09:11 AM
rudolphschenker
Sep 4, 2015 02:41 AM
