tpi intake on a vortec motor
Old Aug 26, 2007 | 06:28 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
hello all, i just got my hands on a free 350 vortec motor from a 97 chevy truck that only had 50,000 miles on it. my question is will my 87 tpi intake work on this block and if not can someone recommend a nice setup that will work. be it a carb setup or efi. i am hoping to pull about 300hp or better.
Old Aug 26, 2007 | 07:05 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Re: tpi intake on a vortec motor
SDPC Vortec TPI Base
http://www.sdparts.com/product/12498...Baseplate.aspx
Old Aug 26, 2007 | 09:23 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
will i need to purchase new fuel injectors also? i have a 305 in the car right now with a set of 19# ford injectors. i believe i should use 21# injectors. and will i need any prom tuning after i make this swap because i have a ecm and chip from an 87 350 tpi car
Old Aug 27, 2007 | 12:27 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
you don't "need" injectors but it would be advised to upgrade and a stock prom for a 350 car of your year would work, a vett prom might be a littel better if your just looking to keep it stock or order one burnt for your setup w a performance tune.
Also edelbrock makes a vortec base plate, but i dont know which is better, anyone?
what year is the car?
if the car's a 305 converting it to a 350 there might be balance isusse w the flywheel if its a stick and if auto use the flexplate for the 350 1 piece rear mains are differant from the 2 piece bolt patters.
Old Aug 27, 2007 | 05:26 AM
Kwik89GTA's Avatar
Edelbrock makes the SDPC vortec intake. They are the same intake.
Old Aug 27, 2007 | 07:43 AM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
my car is an 86 iroc with an 87 roller motor in it right now. so i think i should have the right flex plate because its a one piece rear seal. i think i will go with the sdpc intake, also, if anyone in the st louis area is looking for a freshly rebuilt 305 roller cam motor this one will be coming out soon. only about 6000 miles on a complete rebuild from the oil pan up.
Old Aug 27, 2007 | 10:03 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
24 lb. SVO's are to way to go with your vortec 350. SDPC vortec TPI base is also needed along with a custom chip for your ECM.
Old Aug 27, 2007 | 04:14 PM
socal's Avatar
just a littel advisory if any one can answer the 305 and 350 1 pice rear mains are balanced differantly. I keep getting mixed answers, but theres differant flex plate's for each, balance wise, and teeth wise for sure (153/168)
Old Aug 27, 2007 | 07:07 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
As far as I know, the 5.0, 5.7, and 4.3 engines used the same flywheel, and were 153 teeth. I think the trucks used the bigger flywheel.
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
Steve78LT
Feb 24, 2016 12:15 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
