Cheap and/or easy mods for a 305??
Old Feb 11, 2001 | 03:04 AM
IROC U's Avatar
anyone have suggestions as to cheap mods or mods i can do myself to give my 305 some more hp. i already have k&n filter & dual borla 3" exhaust from the cats back. also, i am thinking of puttin chevy bowtie exhaust tips on. would these hinder the exhaust flow since the tailpipe wouldn't be 3" anymore w/those on?
Old Feb 11, 2001 | 03:51 PM
RoadRocket L98's Avatar
I doubt the tips would be that much of a restriction. Port the plenum, get some high flow runners and either port your base or buy an aftermarker base. Headers will really wake it up too. I realize most of these aren't really cheap, but they will really make a difference compared to the cheapo mods which dont really do anything anyway. Porting the plenum is free.
'83 Firebird 2.8
'89 Firebird Formula 350
2nd owner, red/grey, t-tops, dual cats, and a 3.27:1 rear
K&N, TB bypass, No MAF screens, CAI, full Accel ignition
[This message has been edited by RoadRocket L98 (edited February 11, 2001).]
Old Feb 12, 2001 | 11:02 AM
Steve89GTA's Avatar
I'd like to port my plenum as well (remove those walls just on the inside past the throttle body. If I take the TB and runners off, do I need new gaskets ?
Thanks!
89 GTA G92
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
Crane Ignition
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Feb 12, 2001 | 03:32 PM
85F-body's Avatar
well it matters how cheap you are talking about cause u could get a 180 degree thermostat which is probly the cheapest but i would suggest that you get a cam and then recalibrate your prom
Old Feb 12, 2001 | 03:45 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Changing the gaskets is personal preference... there are those here who will say if you break the seal of a gasket, CHANGE IT!! (Like me, but that's just the Navy's hydraulics training infecting my brain.) But there are others who will tell you that if the gaskets are still in great shape, (good is not good enough) then you shouldn't have any problem re-using them.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Feb 12, 2001 | 07:49 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Just buy the gaskets and don't screw around. They are less than $20 and will save you many hours of headaches.
I'm porting plenums for $60, by the way. I do more than just remove the EGR dams. I spend 90 minutes on each one with the 25000 RPM die grinder and carbide cutters.
Want another cheap mod? Buy yourself a 112 degree LSA cam from Comp Cams, with about 214 degrees duration and install it yourself. Follow it up with a Turbine Tech torque converter for $160. It seems to be a good unit for 305's. Mine is holding up to approximately 285 horsepower from my 305, and has made 31 passes at the strip, with 21MPG on the way home from the track.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
dutch930
Sep 11, 2015 06:58 AM
fbirdroller
Sep 2, 2015 10:27 PM
