cam for street legal
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i'm looking for your opinon on a street legal cam for my 89 5.7 tpi.the whole stock intake has been ported,WORLD PROCUCTS heads 1.94 intake 1.5 exhuast,1.6 rollers.i'm looking for a fairly smooth idel.i need brands,part #'s and prices
1991 banditt2 firebird #130of#600
you should call crane or comp cams tell them what you got and what you want, thats what i did.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
(dont worry i am switching to the 89 ECM)
Brandon
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
ZZ4 cam from Scoggin Dickey for $100.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Engine: 5.7 HSR
i looked for them on there site but couldn't find them,
maybe i'm not looking in the right spot.what kind of info can you give me?
maybe i'm not looking in the right spot.what kind of info can you give me?------------------
I am a big fan of the LT4 Hot Cam. Its the one I am currently installing in my car. I think you could also look at the ZZ9, but its like $400, the LT4 HC is only $180 or so.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
L98 TPI 350 (5.7L)
<font face="Verdana, Arial" size="2">Originally posted by 91banditt2:
</font>
maybe i'm not looking in the right spot.what kind of info can you give me?</font>
Its a great cam for a stock or mild 350 engine. Its my opinion that the LT4 HOT cam requires better heads, intake, and exhaust to make it work up to its potential. Dont forget to get new valve springs too if you're keeping your stock heads.
I have the ZZ9 but all that I read I would get the LT4 Hot cam just cause it is cheaper. I think with some good chip programming, which you could do, your car wouls run like a RAPED APE!
Just make sure you REALLY PORT the intake and heads as much as you can or get new heads and intake.
Don't get me wrong the ZZ9 is great but I spent alittle over $400.00 to get it new!
And I could of had the LT4 Hot cam for half. And I could of had my edelbock intake now instead of the stock!
Good Luck!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Good Luck!
89 IROC 350 Auto
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
the zz4 cam does it fit in 305 tpi lb9??? If you say yes, what are the modifications i am suppose to do (head, intake, spring, exhaust...) My car is stock.
trans-am 91 3.08 posi 5.0 lb9 5 speed stock
Engine: 5.7 HSR
thanks for the link kevin.is the ZZ4 cam emmisions legal?
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Stallone,
The ZZ9, if I'm correct, requires a roller setup, good if your have a roller LB9(305 TPI), bad if not. All 87+ blocks are roller blocks (in thirdgens) If not, you'll need retrofit hydraulic roller lifters, but they cost around $350. Then you'll need new pushrods. I believe you'll also need new springs specially for the cam. You'll also want a cam button or something of that nature. The ZZ9 is good for a TPI motor that will see street/strip use...the powerband is from 2-6k, so you'll want to be sure your 305 is up to making that kind of power in that range. Having TPI, you'll want a ported upper plenum, ported or aftermarket lower, large-tube or siamesed runners, and a computer chip just for that cam. 1500-200 stall converter and a TB airfoil wont hurt, but if you're doing that, why not use a 350 with a miniram and a set of 24# injectors? Same powerband with harder pulling power and less airflow restriction. I guess it comes down to choice. I'll be using a 383 miniram with the ZZ9 and TFS heads for my future motor, but right now I'm just concentrating on getting a 350 to drive around.
No, it doesnt have the emissions legal certification, but its a cam, how is the smog guy gonna know?
Yes, it will pass clean out the tail pipe very easily.
<font face="Verdana, Arial" size="2">89 IROC 350 Auto
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods</font>
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
Is the LT4 Hot Cam a roller cam? I have a pre-87 block and I don't want to spend the bucks on retrofit lifters. Also, what are the specs on the LT4 Hot Cam. Is there a website I can check this out?
Look at the cam tech article on this website for cam suggestions. Yes the LT4 HOT cam is a roller cam.
Street Lethal
Apr 30, 2019 12:14 PM
