Hydraulic Roller ($$$) Vs. Other ($) ?????
Old Feb 12, 2001 | 11:52 PM
Remondi2's Avatar
Why are roller cams sooooooooooo much more expensive than the hydraulic and flat tappet non-roller versions? Can I put on of these cheaper styles in my car and still run rollers on it? I'm running tpi and I don't want to confuse the stock computer setup, so I figured runnning rollers is my only option. Will rolllers work with a non-rolller cam in a roller block? I'm confused....If anybody knows why/whynot to do this I would be glad to listen, thanks.
Old Feb 13, 2001 | 09:21 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
It makes no sense to run rollers on a non-roller cam. The ramps are optimized for a flat tappet lifter. A roller cam has much more aggressive ramps that bring the lifter and valvetrain open much faster. If you used a roller cam with flat-tappet lifters, the lifter would dig into the cam surface and ruin it. The lobes are also ground differently: The roller lobes are flat across the top whereas the flat-tappet lobe is designed to make the lifter rotate. you do not want to rotate a roller lifter or the roller itself will no longer roll! That's why the rollers are typically tied together with a bar or held in place with a sheet metal spider in the lifter valley.
[This message has been edited by ws6transam (edited February 13, 2001).]
Old Feb 13, 2001 | 12:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Roller cams cost more because they're the "hot new thing" and they can charge accordingly. But roller cams are definitely worth the extra money. Dont put a non-roller cam in your car if you have a roller cam now, thats a downgrade.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 13, 2001 | 04:52 PM
a73camaro's Avatar
Rollers cams have been around for decades. Supply and demand curves.
The roller cam is of a harder material that non-roller cams, harder to produce and machine. Roller lifters are more complicated that non-rollers. That drives up cost to produce.
Roller is "tricker" and that also adds to the price.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
