ZZ4 cam how does it idle below 700rpm
Old Feb 14, 2001 | 03:19 AM
evilho7810's Avatar
ZZ4 cam how does it idle below 700rpm? I really don't want to have it idle any higher than that. Right now stock cam and converter it idles smooth as hell at 500 rpm. I want to keep the idle as smooth as possible is this too much cam? If you have this cam please let me know. Also if you have a LPE 219 cam, Lt4, or Lt4 hot cam how do they idle? I don't want a car that surges forward when you let off the brakes I like it how it is right now, would a new converter help?
thanks
Old Feb 14, 2001 | 02:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have a manual trans and it idles smooth at 750 RPMs. Yes I think a higher stall converter would help what you described. The LPE219 and LT4 HOT cam are both big cams with a lumpy idle. The LT4 stock cam is only slightly bigger than a stock 350 TPI cam, and would idle the same.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 14, 2001 | 09:15 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I have an auto and it idles fine. Even 650 rpm is smooth but it will only idle where the computer tells it too.
Old Feb 14, 2001 | 10:23 PM
evilho7810's Avatar
thanks
lt500r55
Sep 1, 2021 01:30 PM
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
camaro71633
Sep 1, 2015 10:24 AM
