Air Injection removal TPI (MAF)
Old Feb 16, 2001 | 11:58 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Has anyone removed their AIR and not set trouble codes or had drivability problems? I'm building a motor to replace my 305 and don't want to waste money and time into air injection. I live in FL so there are no smog checks. The car will be a mild road race car, but still want to be able to drive it around the block
Old Feb 16, 2001 | 12:23 PM
JETHROIROC's Avatar
Took mine off over six months ago, no trouble codes yet, no driveability problems. Just get some brass pipe plugs for the manifolds or get some headers without smog pump tubes. Don't let people tell you it will mess with the O2 sensor output to remove the AIR system either. No fresh air is diverted to the manifolds in closed-loop operation. All that's left is to find the right belt if you're running a serpentine system, and there's an article in the tech section of this board on that with the belt size and routing. Hope this helps.
Old Feb 16, 2001 | 12:27 PM
Steve89GTA's Avatar
I've removed mine aswell (but kept the pump on). Used the brass fittings wich works well. What did you guys do with the electrical collections?
89 GTA G92
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
Crane Ignition
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Feb 16, 2001 | 12:29 PM
Steve89GTA's Avatar
that's connections...
Old Feb 16, 2001 | 02:49 PM
JETHROIROC's Avatar
Just wrapped mine around one of the pipes in the A/C system !
Old Feb 16, 2001 | 04:16 PM
Dana92RS's Avatar
There's a smog pump delete pulley available too if you want to keep the stock serpantine belt and routing. You can read about (and see pictures of) the smog pump delete pulley here and here.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
