Accel 23# injectors w/ stock 350 TPI?
Old Feb 12, 2001 | 06:41 PM
JETHROIROC's Avatar
Will the computer compensate (in closed loop) for the new 23# Accel injectors on a stock 350 TPI? Thanks guys.
Old Feb 12, 2001 | 08:36 PM
Guest
Guest
Posts: n/a
There are people that run the SVO 24# injectors without problems, and some that do. 23 is so close... if you have an AFPR just drop the fuel pressure slightly.
Old Feb 12, 2001 | 10:55 PM
JETHROIROC's Avatar
Thanks for your help. There just aren't any 22# out there (new) for a reasonable price, and I'm afraid the SVO's would be too much.
Old Feb 16, 2001 | 06:27 PM
kevinc's Avatar
Car: 1982 Z28
Accel specifies their 21# injector as stock replacement for L98 applications. I bought a set before having my stockers cleaned & flowed, but haven't put 'em in yet. They're purrrdddyyy. :-)
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Feb 16, 2001 | 06:35 PM
kevinc's Avatar
Car: 1982 Z28
Oops, double-posted...
[This message has been edited by kevinc (edited February 16, 2001).]
Old Feb 16, 2001 | 06:52 PM
JETHROIROC's Avatar
Thanks for that bit of info, man! Yeah, I like the yellow coloring too, matches the Z28 on the dash. Who'd you get yours from?
Old Feb 16, 2001 | 07:00 PM
kevinc's Avatar
Car: 1982 Z28
One word of warning on the Accel injectors, the groove for the fuel rail clip doesn't go all the way around the injector casting like the factory injectors do:
http://members.fbody.com/kevinc/injectors/Mvc-006f.jpg
Its' the second groove down on the Accel (yellow-top) injector. Shouldn't be a big deal w/ a Dremel to cut the groove the rest of the way, but something to keep in mind.
I got 'em from Summit.
1982 Z-28
Old Feb 16, 2001 | 08:55 PM
JETHROIROC's Avatar
Now that's interesting...did it cause you any problems? Thanks for the heads-up, man.
Old Feb 16, 2001 | 09:03 PM
kevinc's Avatar
Car: 1982 Z28
I haven't installed 'em yet. Going to get a few baseline runs with the 22lb stockers first, then switch to these.
-Kevin
1982 Z-28
Old Feb 16, 2001 | 09:12 PM
Shadow's Avatar
Car: 88 GTA Notchback WS6
Engine: 350 with a SuperRam
To those of you that are installing the new Accel injectors, you don't need to modify the grooves in the injectors. Simply use the upper groove that has full circumference. If you notice when you use the upper groove and install the injector in the fuel rail,the bottom o-ring will be in perfect alignment with the original injectors bottom o-ring.
If you attempt to modify the injector and use the lower groove for the retainer clip, the bottom o-ring will be raised too high and will not make a good seal in the intake manifold when the fuel rail is bolted down.
If you have any questions, feel free to email me and I will explain further.
Old Feb 16, 2001 | 11:29 PM
JETHROIROC's Avatar
I'm glad we're getting all this worked out before installation. Shadow, I take it you know by experience with the installation so thanks for that bit of advice. Did it cause any interference with the fuel rail being raised up some, or is it at stock height w/ respect to the intake manifold? Kevin, did you stick with the 21# or go up to the 23#'s and just buy an AFPR to install with it? Thanks for all your help, fellas.
Old Feb 17, 2001 | 10:12 AM
kevinc's Avatar
Car: 1982 Z28
Shadow- using the top groove for the retainer clip will locate the o-ring much shallower in the fuel rail than stock or the 2nd Accel groove. Take a look at the picture I posted earlier. Imagine sliding the Accel injector down until it's top groove is aligned w/ the stock injector's groove.
You'll be putting the o-ring almost 3mm shallower into the fuel rail...the side with gasoline @ 50psi in it. No way I'm doing that. Yes, the bottom o-ring will be ~1mm shallower in the intake boss...but it's vacuum on that side. Make your own call on this one.
I went with the 21# injectors, and already have a Holley AFPR. Just following TPIS advice on using smaller injectors at higher pressures to acheive better atomization than bigger injectors at lower pressures.
-Kevin
1982 Z-28
[This message has been edited by kevinc (edited February 17, 2001).]
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
FormulasOnly
Jul 23, 2018 08:47 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
dusterbd
Sep 29, 2015 08:40 AM
