bought gasket set today plz read need some info
Old Feb 19, 2001 | 01:21 PM
hookin88formula's Avatar
toady i bought the fel pro gasket set for my 88 formula 350 tpi. the p/n is ms 93035-1
my questoin is since i havent taken my runners and plenum off before shouldnt there be a gasket in between the plenum and the intake? cause this kit i got doesnt have one i dont think it has 2 different tb gaskets, distributor gasket, 2 intake manifold side,8 injector seals,intake manifold plenum left and right side 2intake manifold tube short, intake manifold tubelong left and intake manifold tube long right. i thought maybe i am wrong but there should be a square type gasket for the plenum to sit on the intake help me here if i am misunderstood.. thanks!!
maybe this is the wrong set all together but let me know thanks!!
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Feb 19, 2001 | 01:43 PM
custman87T/A's Avatar
there is no gasket for the plenum to intake the only conection the plenum makes to the intake is through the runners.
Old Feb 19, 2001 | 02:00 PM
thanks custman87ta i wasnt sure i liek to buy my stuff before tearing in to anything i thought this should be the right gasket kit but i just wanted to make sure. thanks again. also why does this kit come with a distributor gasket? if all i am doing is taking the runners tb and plenum off i wont need to mess with the dist. will i? thanks again!
Old Feb 19, 2001 | 05:17 PM
You purchaced a TPI intake gasket set which comes with all necessary gaskets you would need if you were to change your intake. I personally was very **** about when I ported my plenum and put an AFPR and wound up changing all the gaskets and replacing all of the bolts with stainless. In my case I used all of them but if you are just taking your plenum off you need only a few.
specialized
Jun 18, 2022 09:26 AM
86IROC112
Sep 7, 2015 01:37 PM
fcorallo
Aug 20, 2015 11:28 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
mizz0313
Aug 12, 2015 06:45 AM
