what happens when U put a 406sb in a 305tpi car??
Old Feb 17, 2001 | 12:19 AM
njdaewoo's Avatar
From: Newark,NJ> Where street racing on I 78 RULES!
I have a question about taking a 305tpi out & dropping in a 406 in it's place with all of the stock 305 tpi parts/etc. the cam will probally be a comp cam exterme energy design with the 112s/angle for tpi. do U think that the car would at least crank up & run after the motor swap?
thanx
njdaewoo
406 sb
dart 200 heads(out the box)
144 B&M blower
373 gears
Edl headers
3in cat back Flowmaster exh.
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
www.njdaewoo@excite.com
New Project car
86TPI trans Am
All stock for now
Old Feb 17, 2001 | 12:46 AM
The Man's Avatar
What year TPI do you have? I have done this before. Mine was off a 85Iroc with a mass air,AFPR,gutted mass,and a few freebie mods. Mine run well, it idle allright, somes it surge alittle in gear but not to bad. It was very strong up to about 4000rpm, then it fell on its face, but everybody knows that. At the worst case you would need a custom chip to be perfect. Aftermarket intake/runners would help alot on upper rpm power.
Old Feb 17, 2001 | 01:41 AM
njdaewoo's Avatar
Its an 86 trans am tpi 5.slow all stock 100%
Old Feb 17, 2001 | 02:19 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Yea, i have to agree, it'd probably all work with minor tuneing issues, but if you wish to see at least 5500 rpms with some pull still pumping out of the engine, most likely new runners, manifold and throttle body would be needed....
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Feb 19, 2001 | 12:59 PM
Z-BOSS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by njdaewoo:
thanx
njdaewoo
</font>
done it no problem.....new chip and new runners port the hell out of the intake and get ready to brake the rear end.
Old Feb 19, 2001 | 09:28 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
And possibly break the 5 speed!
Old Feb 20, 2001 | 12:24 AM
Fastcamaro87's Avatar
the 5spd will definitely break...
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
1nastygta
Oct 28, 2015 08:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
