Good upgrades for an L98
Old Feb 20, 2001 | 06:24 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
What would be some good choices for upgrading an L98? I'm not going to have lots of money, new heads are out of the question at this point.
I'm going to probably put on a totally new exhaust system. 1.75" long tube headers with a 3" Flowmaster cat-back system. I'll also probably get an LT-4 hotcam(should I replace the lifters?)
What else would you recommend?
Old Feb 20, 2001 | 06:45 PM
98_1LE's Avatar
1. Torque converter
2. Nitto drag radials
Trust me, this will net you more than any other mod and will give a solid foundation for later mods. With this a several "little mods", my Fomrula went from 14.81 to 13.94 in the 1/4! I still have the original stock exhaust back to the muffler (which I just replaced) and the stock airbox. The converter I have is the cheal TCI Street fighter. Around town it drives like stock and foot stalls 1800 rpm.
Just my .02¢ +
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
[This message has been edited by 98_1LE (edited February 20, 2001).]
Old Feb 20, 2001 | 06:47 PM
StCr19's Avatar
What about building up the transmission? 700R4s aren't known for their strength...
Old Feb 20, 2001 | 07:08 PM
JAY87GTA's Avatar
That depends on what you have and the miles. A shift kit is pretty cheap and not real hard to do, and will make the tranny holdup better. Unless you're having problems though I wouldn't worry about it. I know my cat-back made a big difference for me. A bunch of people on here can give you by the numbers improvements on what they have. Good Luck and have fun. Later
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Feb 20, 2001 | 08:17 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Learn to burn your own eprom first. Then you can optimize your car for ALL future modifications and get the most out of your hard earn dollar.
Old Feb 20, 2001 | 08:21 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
if your going to put a new cam in it you should put new lifters in.unless you have a roller motor!if you have a 1987 or newer motor you shouldn't need to replace the lifters.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation 1991 banditt2 firebird #130of#600
Old Feb 21, 2001 | 02:26 PM
Dan87IROC-Z's Avatar
If he's getting the LT4 Hot Cam, then he has to have roller lifters because its a roller cam, I don't think you can use flat tappet lifters on a roller cam. So don't replace your lifters. You will need to, however, replace the valve springs with this cam though. And, since you are pulling the heads to do the cam, you might as well install new valve seals, clean up your valves or get new ones. You can also get some thin head gaskets and pocket port your heads. I just got done doing an LT4 Hot cam swap on my car and the project cost me about $600 when it was all said and done.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
NinjaNife
Aug 23, 2015 11:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
