B4C fuel tank......
Old Feb 20, 2001 | 05:39 PM
85ZZ4TPI's Avatar
B4C fuel tank......
I heard that the B4C package had better baffling in the tank so it wont run dry on a hard corner, wondering if they are interchangable and how to get one? Tired of running out of gas when im not...........
ZZ4 crate motor,Stock tuned port,afpr,700R4 art carr shift kit,3.42 posi drums,Eibach pro kit,poly bushings throughout,yadayadayada
Old Feb 20, 2001 | 07:25 PM
85ZZ4TPI's Avatar
Anybody?
Old Feb 22, 2001 | 08:54 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
The B4C and 1LE gas tanks are baffled and have a swinging fuel pick-up to keep the pump from starving with low fuel. I think they also hold a few more gallons (18?). Since these were regular production cars, it should be a direct swap. Good luck finding one.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Mo steel for Mo stremph!
Old Feb 22, 2001 | 02:59 PM
MikeDwhoROCZImports's Avatar
Could you order one from GM? I am going a swap from carb on my 87 IROC to TPI that I've got sitting in my basement, but I'd need to swap in a new tank, so I figure I'll swap in a B4C/1LE tank while I'm at it.
Old Feb 22, 2001 | 05:26 PM
85ZZ4TPI's Avatar
Thanks, But where can I find one?
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
zerogsx
Feb 6, 2016 11:29 AM
RedLeader289
Jan 22, 2016 03:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
