Is there an EGR tube on each set of runners on SD or MAF engines?
I have purchased a couple of used TPI set ups. Some came with an EGR tube on each set of runners and the SD runners came with a EGR tube on only one runner. If you can offer some input I'd appreciate it. Thanks
ODB is correct. 85-92 passenger side runners will all have the EGR tube. 85-88 driver side runners will have the cold start injector tubes. You can use 85-88 runners on an 89-92 setup, just make sure you plug up the injector tube on the driver side.
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
