stop car from smoking!
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
My 85 305tpi trans am smokes when you start it. It emits blue smoke which people have told me is caused by oil being left over in the cylinders. What's the easiest way to fix this problem? Installing new head gaskets?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, its your valve seals. They're correct in telling you its caused by oil in the cylinders. The oil in the heads will leak by the bad valve seals, and will collect in the combustion chamber. When you start the car, the oil gets burned and causes the smoke.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
The only way to fix this problem is to replace your valve guide seals. This would generally entail removing the heads and taking it to a machine shop, or doing it yourself.
However, its not an "its gonna kill my engine" problem, so most people dont bother fixing it.
Clayton
Clayton
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
