Stock map sensor location?
Old Feb 26, 2001 | 12:44 PM
GTARob's Avatar
I am converting my car over to accell DFI. It is an 89 maf car. Where is the stock map sensor located on SD cars? Is there a better place to put it on my setup. I am staying with the stock intake. I have just had it ported, polished, and portmatched.
Robert
1989 GTA TRANS AM
Was a TPI 305 & t-5 car.
Is now 383 stroker w/ the same T-5
World products Sportsman II heads. Lunati pistons and custom ground camshaft. Will dyno after the break in but is estimated at 450 hp and 520 ftlbs. The T-5 is on a suicide mission.
Old Feb 26, 2001 | 01:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The stock MAP sensor location is on the back passenger side of the plenum, where the vacuum ports are. There is a hole tapped there where the bracket mounts for it. You can put it anywhere you want, really, as long as its close to the port.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
squiggy2
Aug 9, 2015 09:30 PM
