Need help with improving my intake base...
Old Feb 25, 2001 | 08:41 PM
Dan87IROC-Z's Avatar
I need to improve the flow of my intake with this new cam I bought. My question is what would cost less and what would flow better between my 2 options.
1. Get a base from a junk yard and have it fully ported and polished by someone. What would that cost?
2. Get an aftermarket base, whichever one is cheapest?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 26, 2001 | 02:42 AM
bttt
Old Feb 26, 2001 | 09:26 AM
shawn87gta's Avatar
Dan,
You can improve on the stock base intake performance by porting and polishing it. However, it can not achieve the same potential as an aftermarket base EXCEPT by extrude honing it - which costs more than the afermarket base. I've been pondering the ported stock vs aftermarket issue for a long time. From what I've gathered, you can do ok with porting until you go to better induction and heads - my car runs pretty good with a stock ported intake. I am upgrading to an aftermarket intake now because I'm going with new heads & Super Ram. I guess the way to approach it is, if you intend to build the car much beyond stock, you will eventually have to buy an aftermarket intake. When you do so is up to you, but with the GP I'm currently organizing this is the best price you'll find.
87 GTA, auto w/2100 stall, 3.27 rear, L98 .020 over,Comp 269HR cam & 1.5 roller tips, ported heads, 52mm TB & airfoil, siamesed SLP runners, port matched plenum, ported intake, Edelbrock TES, AFPR, MSD 6A/Blaster coil, MAF screens, cold-air induction, heated O2, Ed Wright Fastchip.
Soon: ported/polished: Super Ram, Edelbrock intake, Sportsman II's w/1.6 rr's - & burning my own proms.
Old Feb 26, 2001 | 01:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you can port your own intake, that would be the cheapest option. It worked for me all last year. If not, buy an Edelbrock TPI intake (its the cheapest).
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 26, 2001 | 01:48 PM
What should I expect to pay for an Edelbrock base. Also, what would it cost to have my stock base ported?
L98 TPI 350 (5.7L)
Old Feb 26, 2001 | 10:57 PM
88 IROC BOB's Avatar
Check out the GP right now in the TPI section. They are doing Accel base for about $300. I doubt you'll find a better price anywhere else.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Feb 27, 2001 | 02:56 PM
Yelofvr's Avatar
AZ Speed and Marine will port your stock base for $475. It will NOT outflow the Accel base which is part of the GP right now for $300. You decide!
Dave Zelinka
J-money
Jan 4, 2019 09:45 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
hdis2002
Sep 8, 2015 02:52 PM
