heat range for my sparkplugs??
Old Feb 27, 2001 | 02:38 PM
bad camaro RS's Avatar
what heat range would you reccomend? i will be running Nos what brand or type are good for nos thanks mods on sig
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Feb 28, 2001 | 12:47 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
R45TS is what I like on N/A L69's and 350's. NOS, I don't use, but colder for sure...
Definitely go colder for NOS, but check them out after you've hit the juice & see how they look. It's going to be a better driver w/ hotter plugs; change for colder before going to the track. Tune from there!
Old Feb 28, 2001 | 01:08 PM
JETHROIROC's Avatar
For a colder plug you could go with R43TS and use the R45TS when you're driving around town.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Giocio
Oct 1, 2015 12:20 PM
